Toshiba SD220 - Black and White ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stella'd, Dec 16, 2002.
  1. Stella'd
    Stella'd
    Jun 2, 2002
    28
    Devon
    I recently purchased the "multi-region" Toshiba SD220 DVD player from Amazon, but am experiencing problems with Region 1 discs.
    My region 2 discs play fine, but ALL my Region 1 dics play in black & white. I've tried using both the supplied leads and a scart lead, but still only plays them in black & white.
    Has anybody else experienced this problem ?
    Before I go through the process of trying to get it exchanged - I just wanted to check if there is was anything else you can suggest I try.
    Thanks.
  2. sconepanman
    sconepanman
    Are you sure your television can display NTSC signals?
  3. Stella'd
    Stella'd
    Jun 2, 2002
    28
    Devon
    Ahh that could be it - I tried the player on my parents television, I'll give it a go on mine tonight.
    Thanks for that.
  4. Delorian
    Delorian
    I'd say that's what it is, I had to return a region 1 disc there a while ago as it only played b&w or bright pink.
