Toshiba SD22-VB - Is this macrovision?
Discussion in 'Blu-ray & DVD Players & Recorders' started by flemmo, May 28, 2003.
  1. flemmo
    flemmo
    I recently bought a Toshiba SD22-VD (DVD/VCR Combi).
    Sometimes when I tape from the TV the playback is of poor quality.
    When there are dark areas on the picture, the brightness of these areas flickers dark to light.
    It doesnt always happen, or is only visible on certain scenes.
    This sounds a lot like Macrovision. Because the unit it a combi sharing the same scart socket, could the macrovision on the DVD half be causing this?
    If so I could buy a scart macrovision buster. However, will this still carry the RGB signal for DVD component.
    Thanks.
