Toshiba SD210e dimensions
Discussion in 'Blu-ray & DVD Players & Recorders' started by bulldog, Feb 19, 2002.
  1. bulldog
    bulldog
    I`ve just ordered a Toshiba SD210e dvd player and I have
    fairly tight height restrictions for it. I`ve seen conflicting dimensions for it ranging frmo 81 to 102mm. Could someone
    who has one just check this. If its above 88mm I have to
    rethink were I put it.
    thanks
  2. Ron240
    Ron240
    Jan 3, 2002
    3,617
    Kirkcaldy (but i'm not a Fifer)
    +466
    I have a 210e and the correct dimensions are: 430W x 81H x 225D
  3. bulldog
    bulldog
    ok thanks. Just to check, that 81mm does include the feet aswell
    doesnt it?
  4. Ron240
    Ron240
    Jan 3, 2002
    3,617
    +466
    Yes it does :)
  5. bulldog
    bulldog
    Great thanks. That leaves me with a massive 4mm at the top :)
  6. Markster
    Markster
    same problem for me, my tosh210 was just to high for my new sony stand, so ive had to swap it again for a pioneer444.
    Its a bloody good job pionner have bought out these slim little buggers otherwise i'd have been shelling out another £300 for a new tv stand!
