Toshiba SD210 Sound Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by themoron, Mar 27, 2005.
  1. themoron
    themoron
    Jun 30, 2001
    234
    Christchurch, Dorset
    I got a Toshiba SD210 a few years back for a friend and it has just developed a fault. The sound (going through SCART) has suddenly decreased dramatically in volume. Testing it on my system (with different cables) the sound is fine going through coax and optical but again, poor through scart. Any ideas?
    themoron :mad:)
  2. steve1234X
    steve1234X
    Feb 18, 2005
    22
    Hi, i have exactly the same problem as you regarding loss of sound. I notice no-one posted a reply to you, but did you manage to find a solution ??
    Would be grateful to hear from anyone else who sorted this (apparently) common probelm with this machine.
    :D
    Steve
  3. themoron
    themoron
    Jun 30, 2001
    234
    Hi, No I'm afraid it is still sitting in my spare room while I wait for replys on here :(. I've bought her a cheap tesco jobby for now.
    themoron :mad:)
  4. steve1234X
    steve1234X
    Feb 18, 2005
    22
    Makes me quite sick, considering i've probably only used it to watch 10 films max! May try and wangle a fix from Toshiba.
    Steve
  5. DaveH
    DaveH
    Aug 1, 2000
    678
    Surbiton, Surrey
    +20
    My mum has a Toshiba sd2109 (predecessor to your one I think).
    Same problem. It's those damn scarts. Also in completely silent scenes you can hear a low but annoying buzz.
