Toshiba SD150E Multi - Region capabilities?
Discussion in 'Blu-ray & DVD Players & Recorders' started by k5mcl, Jul 9, 2005.
  1. k5mcl
    k5mcl
    We just purchased this dvd player and were wondering if there was any way to play dvds from other regions on this. currently it is set to the UK region. we are aware that you can get firmware disks for most toshiba dvd players to fix this but cannot find one for this model. can anyone here help?
    thanks in advance
  2. dread
    dread
    Did you ever find out about this? I'm getting one of these dvd players and would also like to know if it's possible to play other region dvds with it. I have noticed that some retailers are offering a "Free MultiRegion Upgrade" when you buy this dvd player, so it must be possible.
  3. sparticus
    sparticus
    Nov 17, 2004
    228
    Manchester
    +8
    Owned one for three months and still have not found the firmware for it. The remote hacks for the 240/340/350 do not work on the 150.
  4. dread
    dread
