Toshiba SD140 DVD Player - Any good?
Discussion in 'Blu-ray & DVD Players & Recorders' started by garsmi, Feb 9, 2005.
  1. garsmi
    garsmi
    I am looking at purchasing the Tosh SD140 DVD player from Richer Sounds at £30 Brand New.
    Question is.... Is it any good?
    I have just bought a Sharp LC-37GA4E then realised my current DVD Home Cinema system (Sony DAV-S400) only has Composite connections !!! :confused:
    Does anyone have one of these? Can anyone tell me if it has Optical output for 5.1 digital sound? I want to use Optical out from the Tosh into the Sony for Dolby Digital sound. Also, would the Progresive Scan via Component be any good on a model this cheap? Got to be a whole lot better than the Sony using Composite right?
    Last question, I have seen some websites advertising this model as SD140 and as SD140E are these different models?
    Cheers!!
  2. btb20
    btb20
    Feb 21, 2005
    7
    Did you get one? What do you think?
  3. garsmi
    garsmi
    Hi btb20,
    No I didn't get one... Richer Sounds told me it didn't have Prog scan so didn't bother. Thinking about the SD340 instead.
  4. scottbown
    scottbown
    Feb 18, 2005
    101
    19
    Bristol
    I got a Toshiba SD140, (for the bedroom) and the box says Progressive Scan.
    It's a good, DVD player, and in my opinion for the RicherSounds price of £30 it's the best value DVD player on the market.
    Plus it has the outputs for 5.1 and component out, so if you wanted to use it with a AV Amp it's plenty good enough.
    Anyone know a Multi-Region code/hack for it?
    Cheers, Scott
  5. Rave
    Rave
    Aug 18, 2004
    9
    My local Tescos has the SD-240 for the same price. Probably a clearance offer so stocks will vary.
    The SD-150 is out now (or soon) which apparently offers DiVX playback for not much more money.
  6. jerkyboy
    jerkyboy
    Where did you get a Sharp LC-37GA4E from, I thought there were none left in the entire world !!
  7. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Its a great little machine, I bought one for a mate on his Birthday and consdering it costs less than a tank of petrol I don't think you can go wrong really :)
  8. chrislewis
    chrislewis
    Jan 13, 2005
    2,480
    wolverhampton
    +25
    sorry to hijack tring to pm you thunder but your full
    chris
