toshiba sd100e
Discussion in 'Blu-ray & DVD Players & Recorders' started by gargoyle, Feb 15, 2001.
  1. gargoyle
    gargoyle
    Nov 8, 2000
    630
    birmingham
    +24
    can anyone out there tell me if there is a fix for the tosh to enable it to play region one?
  2. clone
    clone
    No , there is no handset hack for the Toshiba players.
    You have to pay to get it modified for multiregion.I personally would recommend www.upgradeheaven.co.uk
  3. gargoyle
    gargoyle
    Nov 8, 2000
    630
    birmingham
    +24
    Clone -
    Much thanks for the info - situation sorted!
  4. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    and if you go to www.thedvdforums.com and go to the suppliers forum then click on the upgrade heaven thread, there's a discount voucher for any multiregion modifications. I think it's £50 all in which is quite a bit cheaper than normal.
