Toshiba SD-900E Remote Codes
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jasonjo, Apr 18, 2002.
  1. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Has anyone got a list of IR and discrete codes for the SD-900E remote control? I can learn most, but it would be nice to get discrete (i.e. not just togle codes) for on/off etc...
    Preferably in CCF (i.e. Pronto) format...
    Tried www.remotecentral.com with no luck...
    Thanks in advance...:)
    JJ
  2. gkill
    gkill
    Did you ever get a solution for this problem? My SD 900E remote has got lost in a house move and I cannot get the oneforall universal remote to work with the player, so am hoping that somebody out there has the remote control codes?
