Toshiba SD-63HK Picture Distortion
Discussion in 'Home Cinema Buying & Building' started by peterbull14, Oct 7, 2004.
  1. peterbull14
    peterbull14
    Jun 20, 2004
    10
    Derby
    Hi, I've had two Toshiba SD-63HK home cinema kits from RGB Direct and they have both had the same fault. There is heavy distortion to the top and bottom of the screen when playing back a dvd. At first i thought this was just a problem with the scart cable, as it started working properly when i switched them, but not soon after the problem started again. Any thoughts on what this could be, because i really don't want to have to send another one back! :lease:
