Toshiba SD-530E Viewing Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by ant_ponte, Mar 20, 2006.
  1. ant_ponte
    ant_ponte
    I have a toshiba SD-530E and am having problems. I can view and listen to any recorded/copied dvd's and music cd's, however, when I try and play an original DVD i only get sound and no picture, the screen is blank....I have it connected to my LCD with an HDMI Cable which works perfectly for copied DVD's.....
    Any ideas???
  2. ant_ponte
    ant_ponte
    has anyone any ideas with this one???
  3. MI55ION
    MI55ION
    Nov 8, 2005
    5,851
    +690
    That there just might be your problem, if I recall correctly that model does not have a hdmi output. Try components if your telly accepts this, as it will do the job just fine.
