Toshiba Sd-43HK dvd- where can i find help with protection problems
T
tooty
When i turn on the dvd player the word protection appears then turns its self off, does any body know how to solve this problem.
zoodemon
hi it's quite a common fault with this unit, mine having just done the same.
wondered if anyone had any quotes for fixing this as mine has done the same? if not can you get a replacement unit or buy another dvd and amp that will work with the speakers?
cheers
