Toshiba SD-350E advice needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by stravinsky, Oct 28, 2005.
  1. stravinsky
    stravinsky
    Jul 26, 2005
    24
    Pontefract
    I am considering buying this DVD player.
    My Amp though will only take Optical Audio connections (Toslink).
    Looking through the specs on various sites, some say this DVD has Optical Audio out and some say it is Digital Coax only.
    Can somebody who has this DVD please tell me if it has Optical Audio out.
    Thanks in advance :lease:
  2. wandgrudd
    wandgrudd
    Dec 16, 2002
    184
    Nottinghamshire
    +7
    definitely Digital Coax only
  3. ase001
    ase001
    Dec 1, 2004
    264
    Stoke
    +6
    You can get an optical to coax or a coax to optical converter from Maplins (www.maplin.co.uk) for about £15. I’m considering using this as I have the same problem. With it being digital audio it should not lose any audio quality.
    Maplin part numbers
    Coax - TOS Covertor L73BA £14.99
    TOS - Coax Covertor L74BA £14.99
    Optical to Coaxial Digital Audio Convertor Manufacturer: Nikkai Connect!
    • Converts optical (Toslink) digital signals to electrical (phono)
    • Includes plug-in mains power supply
    • Solves problems connecting digital audio equipment with incompatible connections
    • Ideal for Home Cinema and hi-fi use
    Converts the optical digital output from a Toslink to an electrical S/PDIF coaxial signal. The features a standard Toslink input socket, a phono output socket and a DC power socket. Plug-in mains adaptor included.
    :hiya:
