Toshiba SD-350E advice needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by stravinsky, Oct 28, 2005.
  1. stravinsky
    stravinsky
    Jul 26, 2005
    24
    Pontefract
    I am considering buying this DVD player.
    My Amp though will only take Optical Audio connections (Toslink).
    Looking through the specs on various sites, some say this DVD has Optical Audio out and some say it is Digital Coax only.
    Can somebody who has this DVD please tell me if it has Optical Audio out.
    Thanks in advance :lease:
  2. po_man
    po_man
    Dec 23, 2004
    1,712
    St Albans
    +63
    I don't think it does. When this DVD player was first listed on their website it was quoted as saying "Optical audio" connection, but it has since been removed from their site.
    The american version, the SD-4980 does have the "Optical out" connection.
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,791
    London
    +555
    As far as I can recall it was co-ax only.
  4. ase001
    ase001
    Dec 1, 2004
    264
    Stoke
    +6
    You can get an optical to coax or a coax to optical converter from Maplins (www.maplin.co.uk) for about £15. I’m considering using this as I have the same problem. With it being digital audio it should not lose any audio quality.
    Maplin part numbers
    Coax - TOS Covertor L73BA £14.99
    TOS - Coax Covertor L74BA £14.99
    Optical to Coaxial Digital Audio Convertor Manufacturer: Nikkai Connect!
    • Converts optical (Toslink) digital signals to electrical (phono)
    • Includes plug-in mains power supply
    • Solves problems connecting digital audio equipment with incompatible connections
    • Ideal for Home Cinema and hi-fi use
    Converts the optical digital output from a Toslink to an electrical S/PDIF coaxial signal. The features a standard Toslink input socket, a phono output socket and a DC power socket. Plug-in mains adaptor included.
  5. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,067
    Essex
    +73
    i have this player connected to my bose lifestyle system for the sound and im pretty sure i have connected it via Optical Audio out
    i will find out for sure later on though, but im 99.99% sure it does has an Optical Audio out port, but i may be wrong
  6. stravinsky
    stravinsky
    Jul 26, 2005
    24
    Pontefract
    Thanks for the help.
    Still not sure if it has Optical or not as some of the reply's differ.
    I suppose I will have to try and find one in the shops and get a look at it.
    If it hasn't I'll look at the convertor from Maplins.
    Thanks again :confused:
  7. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,487
    Surrey
    +115
    I have a Toshiba 350e (see my post about audio problems!)
    I can confirm that it only has a Coaxial cable output as I had to dig my old one out when I installed the new player last month.,
    There is definitely no Optical output.
  8. verwood
    verwood
    I had a similar player and it was really good, but it really struggled to play DVD-R and DVD-RW discs (dispite what it claims). It was also very slow at playing MP3s
    Not sure if this is important to you, but I thought I would point it out... I swapped it for a Cambridge unit, which is faultless (and it has loads of connections).
    PS I don't work for Richer Sounds!
  9. SuperSeven
    SuperSeven
    Oct 29, 2005
    576
    28
    +30
    350e arrived today from RGBDirect and it's only coax - no optical.
    Seems very good and has played all my single layer DVD-R and DVD+R discs.
  10. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    *SORTED OUT*
    I'm after SD350*E*, richersound does not price match with region 2 SD350 (cheapest £74.64).
    If i take SD350 from richersounds, would i able to hack for multiregion?
    Many thanks
    Sunil
  11. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    sunil
    yes the hack works and i bought from richersounds. There supposed to beat a competators price by 5%. ask for a pixmania pricematch
    Do not buy for hdmi though!
    Azz
  12. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Thanks! got for £68
  13. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,791
    London
    +555
    You're that certain but you maybe wrong ? LOL :D
    Well, it doesn't have optical out for sure.
  14. fraser01
    fraser01
    Oct 15, 2005
    HI just bought this dvd player and have connected it via coxial to my amp with excellent results .You need to buy a coaxial to digital cable .
