toshiba sd-350 - removing the horrid blue bit..
Discussion in 'Blu-ray & DVD Players & Recorders' started by 5lab, Sep 11, 2005.
  1. 5lab
    5lab
    Feb 13, 2003
    46
    lo guys
    well as some of you who own a tosh sd350 may know, there is a horrid bright blue line across the front which you cant get rid of permanently.. well.. ya can
    the solution is simple - open the drawer, and apply a small bit of electrical tape to each edge of the drawer. this will completely stop the light going down the front.. you still get a splash at each edge though..
    i've experimented a bit, and i find that 2 layers of masking tape at each edge of the drawer. this dimms the front nicely. its pretty bright now at each edge, but dims to practically nothing in the middle. this looks much better than origionally imo..and its not anything like permanent, so you can remove it if you wish :)
  2. Ikarus
    Ikarus
    There is an option to switch it of in the config menu.
    Mine is off :smashin:
  3. 5lab
    5lab
    Feb 13, 2003
    46
    it'll come back on next time you turn it on.
