Toshiba SD-330e - dark?
M
Mox
Hi, I have the above player and it does what I want - I'm currently investigating r+ and - issues but that's another storey :) - anyway, when I play DVD's the picture always seems a bit dark and adjustiing the TV controls does not seem satisfactory.
Any suggestions?
TIA.
M
Mox
EPM has helped - I went from normal to light. It would be nice if there was a double light mode though :) - cheers for that.
robbster
What connection are you using to hook up the DVD player to the TV? The reason I ask i because I used to have a toshiba DVD player and sony widescreen and the picture always looked too dark to me too. That was through RGB, I then tried it through s-video and the problem dissapeared. I'm guessing it was some compatiblity issue but i'm no expert.
Hope this helps
Rob
M
Mox
What an interesting idea! I went back to the manuals for the Tosh and Sony, set up S video on the dvd and switched scarts on the TV and I think that there is an improvement! - Difficult to tell at the moment as a bit sunny...
many thanks
Mox.
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
