Toshiba SD-240E Anyone got a hack please.
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by booktrunk, Jul 17, 2004.
  1. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    As per the title.
    Any help would be appreciated.
    steff
  2. WILD9
    WILD9
    Mar 12, 2003
    156
    Cheltenham
    +6
    Just got hold of this one :
    open the tray
    type 2403960
    press enter untill youve cycled through to region 9
    close the tray
    turn th eplayer off
    turn it back on
    its now region free, not tested with rce yet tho
  3. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Hiya,
    That worked great.
    Thanks a lot.
    Steff
  4. moomin
    moomin
    i put this hack into my tosh 240E and now it wont read any DVD's on american ones it gets as far as the FBI warning , and on english ones it does nothing, is me putting the hack in ralated? or was the player just screwed to begin with? (it was playing english dvds ok before) and yes i did make sure that region code 9 is displayed, i also tried setting the player to the region disc i was trying and still it would not play.
    cheers in advance
  5. RedLakie
    RedLakie
    Nov 7, 2004
    2
    Just worked a treat for me ... Got the player from the local tesco's in Loughborough, few pence short of £55 ... Absolutely stunning for the £££'s!
  6. Origin
    Origin
    RedLakie - Have you actually tried a region1 disc yet? Does everyhting else work as normal? I just want to be sure the hack won't mess up the player at all...
    NB: I just bought the same player from a Tesco's in Cardiff - £5 less than Richer Sounds!
  7. RedLakie
    RedLakie
    Nov 7, 2004
    2
    Hi Origin,
    Yep, seems to play a range of R1 Disk's - Only thing I have noticed is that my "backup" dvd r's now appear as invalid disks ??? Have been working away for a while and not had a chance to play, I will let you know if i hit any other problems.
