Toshiba SD-240
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by yahkjr, Sep 27, 2004.
  1. yahkjr
    yahkjr
    Jul 9, 2004
    28
    Just bought the above from Richer sounds and, according to a label on the box, the following makes it multi-region:
    1. Open disc drawer.
    2. Using remote, key in 2403960.
    3. Press Enter on remote until region code 9 is displayed.
    4. Press the power button.
    The player was supposed to be multi-region when I bought it but I have not tried a non region 2 dvd yet so do not know if this works.
    Kenneth.
