Toshiba SD 220E picture freezing
Discussion in 'Blu-ray & DVD Players & Recorders' started by johnnymcc, Jun 13, 2003.
  1. johnnymcc
    johnnymcc
    All,
    has anyone experienced picture problems with Tosh. SD 220E DVD player. I intermittently get picture break up , blocks / lines appearing and the picture then freezes then releases but sometime freezes permanently !!
    J.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,370
    United Kingdom
    +1,736
    Had a similar problem with my old Toshiba 210. Have you tried a lens cleaner?
  3. Peter Shilton
    Peter Shilton
    Jun 8, 2002
    213
    19
    Solihull
    There is quite a lot of info on this. Do a search.
    What version 22o have you got. They have a thing called firmware which says which version it is. Versions 1.3 had a lot of problems. mine is 1.4 which I believe is OK, I think it is on 1.5 or even higher now.
    It says on the box, if you still have it.
  4. johnnymcc
    johnnymcc
    thats for that . i'll check the version using zoom, 6, 0, 6, zoom....
    Can new f/w be downloaded from the web anywhere or will can the dealer sort it under warranty ??
  5. mike5
    mike5
    I got my old Toshiba SD 3109 firmware upgraded to 2 .4 from Toshiba which has helped in a lot of problems. It even plays Verbatim DVD-r which it never done before.
  6. Zone
    Zone
    Jun 24, 2001
    6,736
    Barnsley
    +2,424
    Personally I'd start by making sure the discs are clean first...
    If they are then all of the above :)
  7. lespaton
    lespaton
    Yes, dirty disks. I found my m/c gave all kinds of problems similar to yours when it encountered debris on the disk surface...fingerprints, dust etc. Cleaned the disk and problems disappeared.
  8. Peter Shilton
    Peter Shilton
    Jun 8, 2002
    213
    19
    Solihull
    "I found my m/c "
    What the hell were you doing playing discs on your motorcycle?!!!!!!:)
  9. johnnymcc
    johnnymcc
    My 220E has Ver 1.5 which seems to be latest version.
    Is there such a thing as a DVD disc cleaner or does the m/c need opened to clean the lens ?
