Toshiba SD-210 EB: disabling macrovision?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bert Coules, Apr 10, 2002.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
    I see from a search on these forums that it's possible to disable macrovision on the Toshiba SD-210 EB. Is this a feasible DIY job? If not, are there any recommended dealers or repairers who will carry out the mod on an already-purchased unit?
    Thanks in advance.
    Bert
    http://www.bertcoules.co.uk
  2. Markster
    Markster
    Always a hassle and costly if you havent bought a ready chipped mulitregion toshiba player straight off.
    You will probably have to use techtronics.com who do offer this service. Theyre not the greatest of vendors but you don't have that many options im afraid.
    hth
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
  4. laurel
    laurel
    If you've already purchased the player, you may be better looking at an external unit, such as the one from lectropacks.
    Take a look here
    at the Stab Video Copy Enhancer, £34.95.
    As long as your only copying to VHS, this is fine (composite only).
    If you need S-Video (S-VHS), then you'll need the CM1 at £59.95. This also allows adjustment of sharpness/colour etc.
    There are other similar units from other manufacturers.
    You can then use the unit with any player.
    Laurel
  5. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
    Laurel, thanks for the thought. My main need is to be able to dub to VHS, so a separate component-only box would be fine.
    Or does disabling macrovision make so noticeable an improvement via the higher-quality outputs that it would be worth having for ordinary viewing too?
    Bert
  6. laurel
    laurel
    No, you won't notice any difference on normal viewing. Macrovision only affects the recording device i.e. VCR, as they are designed to do this.
    Laurel
  7. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
  8. laurel
    laurel
    Bert
    Yeah - that should do you just fine.
    But dont forget;
    ;) :D
    Laurel
  9. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,369
    +163
    Oh damn. There goes that idea, then...
    Actually, I do approve of the copyright laws in general, having lost (and continuing to lose) a certain amount of income myself through people flouting them.
    My own reasons for wanting to disable macrovision don't involve anyone else but me seeing the copies - and I've already paid for the discs...
    Bert
  10. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    CPC have a selection of Macrovision tools eg, part#[email protected]£34.10.That is only one of many.hth
  11. Guest
  12. Geoffc10
    Geoffc10
    Another reason to disable macrovision is that some tv's cant handle region 1 discs very well( the picuture bend at the top of the screen).
