Toshiba rxs32 clock problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by tiger3176, Jun 1, 2005.
  1. tiger3176
    tiger3176
    Hi everyone, I have a Toshiba rxs32. I have had it 10 months now and it has worked perfectly. The trouble is, for the last couple of weeks, the clock has been altering itself half an hour forward every day. I have to manually reset it everyday, or else it tapes the wrong programes.I can't fathom it out. Exactly 30 minutes forward every day. I wonder if anyone can help me please? Thank you.
  2. knotpc
    knotpc
    Nov 29, 2004
    431
    Peterborough
    +18
    If you have a UHF aerial attached to the Tosh and have BBC1 set at channel 1 on it, set the time to auto, it should pickup the time from the teletext signal. I don't know if the Tosh uses little lithium batts for the clock and certain memory functions, if it does you could have a flat battery. :beer:
  3. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
  4. tiger3176
    tiger3176
    Thank you. I will try what I have read, that is, I have turned off "just clock" and set the channel to 99. I will see what happens tomorrow.
