Toshiba RPTV 42wh36 question
Discussion in 'Televisions' started by jaima, Jul 24, 2005.
  1. jaima
    jaima
    May 9, 2005
    15
    hI all, :hiya:
    Got a question about my tosh, when i am viewing, i think that the outer screen is too dark ?, also when i put the set onto the blue screen this seem`s to confirm it, the screen is bright in the centre but the outer is dark/dull by about 6 inches, top, bottom and both sides of the screen !.
    With this tosh being my first RPTV, is this normal :confused:
    The set has been like this since i got about 6 weeks ago, i have done the convergances but not in the engineers menu.
    Thanks for any advice :)
    jaima.
  2. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,158
    oxfordshire
    +283
    i have noticed the corners are slightly darker on crt based rear projection sets like yours, I used to have the 50 inch version and it was a bit noticable on that. i don't think its a convergance issue, have you tried using a disc like avia, video essentials or the thx set up on certain dvd`s to set your tv`s brightness and contrast etc. up correctly.
    Can you post a pic of the fault, if its really bad might be worth getting an engineer out
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,975
    This isn't a DLP set, so, moving.....
  4. jaima
    jaima
    May 9, 2005
    15
    LV426 sorry about that.
    @ thekingbeyond: I had not set up a dvd player (have now) and did as you said with the contrast/brightness and it looks a lot better now m8 !.
    Thank you :thumbsup:
    jaima.
