Toshiba RP TV, 40 PW03B...
Discussion in 'General TV Discussions Forum' started by bubble_69, Mar 24, 2001.
  1. bubble_69
    bubble_69
    I am seriously considering about buying this TV after seeing it in Comet the other day.
    Is there any serious problems I should be introduced to before spending my hard earned readies on.
    I mainly have R1 DVDs and watch alot of OD if that helps, are there any other TVs in that size range that could be considered for purchase
    Thanx
    [​IMG] Bubble [​IMG]
  2. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    The Toshiba 40WHO8B (note this ref. number, this tv has 100Hz which works very well and also component input), is by far the best choice. Also check around for the best buy, you should be able to pick one up for less than £1600, - try Sound & Vision Bolton. Comet are not the cheapest and don't give the best service. Be wary and good luck!
  3. MacReady
    MacReady
    I would go for the WH 08B too. I had the Wp 03 for a while and it was replaced by the WH when the WP developed a fault....I am glad it did.
    My Wife and I were getting terrible headacjes from the WP due to the lack of 100hz processing. I know a lot of people dont like 100hz (me included) but the WH handles it much better than any other set I have seen, and since owning it we have not suffered from any headaches from watching the tv.
    You may not see any flicker on a 50hz CRT set, but when you start to move up to a set of 40" upwards it becomes VERY noticable.
    "Why don't we wait here a while...see what happens..."
    The member formaly known as Jason
