Toshiba RP convergence problem!!!
Discussion in 'General TV Discussions Forum' started by raigraphixs, Jul 11, 2002.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,113
    +23,984
    I have a problem with convergence on the set and need advice.
    On checking the convergence on the normal menu, the blue was out all over after about 30mins usage, so i tried to align the cursor 1 (blue), and going back to the film the blue was out big time, and nothing seemed to help.
    So i entered the service menu and tried to align the grid up on the blue, now im not sure if the next problem, i cause or was already present when i entered the service menu, but look at the dummy pics i made up;
    see image attached-
    pic1.jpg - 'normal service menu', the blue is angled up on the left.
    pic2. the 'service engineers' menu; the grid shows the blue curved up problem!!, and trying to bring it back in line, does not work at all.
    Is there any kind of reset to factory option, maybe this will work, or does anyone know how to fix this, or what caused it.
    I will get a tosh engineer in to look at it, if no one knows. Do you think he can do this on site?.
    thanks
    rai
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Well.....that's a problem....
    I have not played with service menu's of this unit. Does it have a zone convergence....I take it that if it does you've tried topleft pincushion....I would suggest a Tosh engineer is the first port of call.
    Gordon
  3. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Just curious, you did let the set warm up for 40 minute before adjusting the convergence?
    Then once youve adjusted the convergence did you turn the set off to let the changes take effect?
    Looking at the pics it seems the whole top left is out big time, so why cant you use the normal convergence menu to bring the blue into line? The Service menu is only used to bring individual squares into alignment not whole blocks.
  4. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,113
    +23,984
    Yes i did.
    Something went wrong. I try normal convergence again friday.
    Anyone know how to reset to factory settings, is this possible????.
    Also i am trying to get on ''uk.media.home-cinema'' forum, but it is not working, Ian once asked the same question about 'reseting' (spelt that way by him) the convergence on 40who8b.
    thanks
    rai
