Toshiba RP - A Problem ?
Discussion in 'TVs' started by B-LINE, Aug 24, 2003.
  1. B-LINE
    B-LINE
    Hi People ,
    Nice to see a forum to help people like me out with gadgetry problems :blush:
    Ok ive just taken delivery of a new model Toshiba 43VJ22P Rear pro
    I have a problem though, when watching TV programs that have the black borders, widescreen for instance , it looks as if the picture is dipping/Tilting to one side, if you imagine a picture on a wall thats slightly tilted and you can see that it just isnt straight and it needs putting straight.
    Thats as best as i can describe it, anyhow its now getting on my nerves as once you notice it you cant forget its like that
    I was going to call the online retailer where i bought it from, however just looking at my normal sony 21 inch in the bedroom its has the same problem except it dips/tilts to the opposite side ,
    Pictures on both TV's are not too good, im thinking because of the ariel , Shadows on some channels etc , but is there anything i can do to sort this and the main problem of the picture dipping/tilting to one side on the Tosh RP, its driving me insane and i really cant live with it , of course my wife cant see a big problem but i can ....help ! :(
    Apologies for the long post , its just driving me up the wall.
  2. dupfold
    dupfold
    Hello!
    Glad I'm not the only one! I have a Tosh 42wt29b with the same problem. The picture slopes slightly down from the left to right. I've had the engineers out and he fitted a new part. But now i've noticed it again and it is driving me crazy! Let me know if you find a way to correct this
    Dean
  3. B-LINE
    B-LINE
    Hey !
    Im looking into it, im thinking its the ariel and im going to try getting a signal booster or something , at first i thought it was just my Toshiba RP but my sony is like this as well so it cant be a toshiba/TV fault.
    I wouldnt mind so much but on a big TV you can notice it, will post back when i know more
    Anyone with any input on this at all would be good
  4. dupfold
    dupfold
    I can imagine a booster would fix the shadow problem but surely not the tilt problem?
    Let me know how you get on
  5. B-LINE
    B-LINE
    I need it anyway , Worth a try i suppose :(
    Ive been reading on this forum about this AVIA setup thingy , do you think that would sort it ? or have you tried
    I have no real knowledge of RP Tv's , i was a virgin with them but now ive had my first one lol
  6. dupfold
    dupfold
    I was also a RP virgin so I'm no expert! I've read a lot too about this Avia dvd. Not sure what it does but I would like to find out.
  7. nathan_silly
    nathan_silly
    To adjust picture tilt you have to adjust the neck of CRT tube. The service manual has info on this.
    My set also is tilting about 1 degree clockwise. Pity there is no user menu option- a mates old Sony CRT has this.
