Really nice and professional review Mark, as already posted in previous thread I appreciated your work.
Two questions coming:
- for what concerns red undersaturation: do you think it's a matter of the panel or otherwise it just an electronic controller that could cause it?
In other words, do you think that a firmware update could solve or partially fix the issue?
- as far as we can guess, the 42" panel could be an LG one while most probably 46 and 55 panels are from Samsung. Do you expect same cons, expecially talking about red desaturation and 3D performance side by side, could be find in 46" and 42" models?
- Will Toshiba provide a feedback on the review, and maybe clarify if some issues will be taken into account and solved by a firmware update?
Thanks again and keep up with the good work
