Emy
Hi all,
Just received the Toshiba Regza 32SL863B from Amazon. The installation went ok, after a few hours (the TV was connected to internet), I have got a message saying that there is a software update available.
I updated it and after a while I turned it off. After a few hours I turned it back on and surprisingly there was no sound at all, checked everything, no chance. I tried to revert to the factory settings, I could not find it, just the Reset TV, it resets to the initial configuration that came with, no old software/firmware.
Whenever I turn it on there is an attempt of sound, just a second, after this the sound is no more.
I tried to find the previews firmware but I could not find it. It seems that the latest software is causing this.
Apart of this issue, the TV looks OK. I like the stand, it is very strong made.
I tried to contact Toshiba support but it seems that is notthat easy.
Any help/suggestions are welcome.
