Toshiba Rear Projection .... Lifespan?
Discussion in 'General TV Discussions Forum' started by conington, Apr 29, 2002.
  1. conington
    conington
    Mar 6, 2002
    259
    Colchester
    +6
    I have both a Toshiba 56inch and 40inch Rear Projection TV, both very nearly 2 years old now, I have read negative reports on the life of rear projection sets and the cost of replacing "bulbs". Has anyone any idea on what sort of life (hours) I should be able to expect?
  2. carsten_f
    carsten_f
    almost all of the Toshibas including the 56" use three picture tubes with a life expectancy which is almost similar to a conventional tv picture tube (MTBF 10.000 hours?).
    The 40" may be an LCD rear projection model, in which case there should be a single bulb with a shorter life span.
    Regards
    Carsten.
  3. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    My 40" Toshiba RP is now approaching 4 years old and still going fine.
    This particular model isn't LCD based btw.
    Mark
