Toshiba RDXS34 - worth waiting for?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chewyjoint, Jan 17, 2005.
  1. Chewyjoint
    Chewyjoint
    Jan 9, 2005
    10
    3
    I had just decided to buy a Toshiba RDXS32 when I saw several mentions in this forum of the new RDXS34.
    Question is whether it's worth waiting for the newer version?
    I understand that it will have a digital tuner (which I think means I'll be able to get the digital freeview channels?) and a larger hard drive.
    This US site www.cybertheater.com/archives/2005/01/toshiba_rdxs34.html
    suggests a retail there of $499.
    Any opinions on this would be appreciated.
  2. quinn45
    quinn45
    Yeah I would wait, the new model has double the HDD space of 160GIG. Also it has been said that Toshiba will release a 250GIG when they annonce there new models fairly soon !!!!.
    The new model(s) are slated for a March release - just hold on a bit longer. !!
    I have a RDXS-30 - 60 GIG HDD is a bit tight !!. I will get Toshiba again just need a bigger HDD please Toshiba !!!!
    Quinn
  3. JayCee
    JayCee
    Jan 20, 2004
    22,187
    Lanarkshire
    +2,308
    Yes, I would hang fire until the new models are released.
    I bought the RD-XS30 last Feb.......just a couple of months later they released the RD-XS32 with better features.
    I am extremely happy with my Tosh, it has performed brilliantly but no matter how big the HDD is you always end up needing/wanting more space.
    I got Sky+ last week so that has given me a bit more space but I do fancy the upcoming RD-XS34 with the bigger HDD and the built-in digital Tv does make sense............but mind you I think it will be pricey!! We in the UK always end up paying in Pounds what the Yanks :) pay in Dollars don't we?
  4. rogerh
    rogerh
    Jul 4, 2004
    431
    Maidstone
    +10
    Sounds as though this might be the machine to go for. I was going to buy the Sony 900 but decided against as it doesn't have a digital tuner.
    However will the picture quality and build quality be as good as Sony?
    I'm impressed by the 2 pass system Sony use when dubbing and I have to say that I have always considered Toshiba a poorer quality manufacturer (Yes it's bias)!
    I've looked at the site Chewjoint refers to and on the Toshiba site. Both give info. but the only tuner I see refered to is the NTSC one.
    Where did the Digital Tuner info. appear?
  5. jackpot
    jackpot
    Dec 29, 2004
    77
    It also says on that link that it has a 160GB HDD. I'm sure i've read somewhere on this site that it will have 250GB
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    jackpot, UK spes will almost certainly be different. The RDXS34 may even get a different model number for the UK. It's wait and see I'm afraid. All info on the 250GB/Freeview tuner/EPG can be found in What Video & Widescreen TV's upcoming kit preview - and they are normally pretty spot on with their announcements.
  7. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    I am sure I have read that the Sony editing features are somewhat rudimentary compared with most other HDD/DVD machines.
  8. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes, the Sony editing functions are limited. If you don't need those functions, reports are it is a top quality machine; but make sure you understand what you want to do with it and the limitations before you buy. I considered the Sony until I found out you can not take a long recording and split it up; e.g. record a 3 hour program and edit it to put it on 2 discs of 1.5 hours. This is something I want to do. So I went for the XS32. I did think about waiting, but I got "the bug" and couldn't wait.
    Mark
  9. rogerh
    rogerh
    Jul 4, 2004
    431
    Maidstone
    +10
    The other problem as I understand it with the Sony, is that it doesn't allow you to vary the settings for quality/against recording length when transferring from HD to DVD.
    If a recording is 1hr 5mins it will automatically reduce the quality of the whole hour and not allow you to just slightly alter the quality to get fit to a 1hr dvd.
  10. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    Instead of splashing the cash for a new dvd recorder why not do the diy upgrade and change the sky plus drive? You'd probably save a lot more doing it that way anyway...
  11. JayCee
    JayCee
    Jan 20, 2004
    22,187
    Lanarkshire
    +2,308
    Yes, I'll probably get around to doing this. I've only had the Pace V2 Sky+ for about a week so I'm just going to leave it a few weeks and get to know it and put it through it's paces before upgrading.
  12. rogerh
    rogerh
    Jul 4, 2004
    431
    Maidstone
    +10
  13. JayCee
    JayCee
    Jan 20, 2004
    22,187
    Lanarkshire
    +2,308
  14. rogerh
    rogerh
    Jul 4, 2004
    431
    Maidstone
    +10
    Sorry about that. I've tried again and now I can't get it!!!!!
  15. rogerh
    rogerh
    Jul 4, 2004
    431
    Maidstone
    +10
  16. JethroUK
    JethroUK
    Dec 5, 2004
    1,144
    +34
  17. rogerh
    rogerh
    Jul 4, 2004
    431
    Maidstone
    +10
    Thanks JethroUK
