Toshiba RDXS34 - timer program
Discussion in 'Blu-ray & DVD Players & Recorders' started by rap451, Jun 12, 2005.
  1. rap451
    rap451
    Hello to all,
    The timer record system for the RDXS34 is easily to use and set up - but once activated should the unit remain on after the timer record program has completed, i.e. .....
    unit programed - via maybe videoplus
    system turned off - placed in standby
    system turns on - records program as expected
    timer program completes
    system stays on - unlike old VCR technology were unit turns itself off
    Is this normal RDXS34 behaviour?
    Thanks in advance for your help.
    Richard
  2. sinclair
    sinclair
    No, the unit returns to the state it was in before the recording begun.
  3. sohe68
    sohe68
    Jun 9, 2004
    65
    11
    Stockholm
    +14
    This is optional behaviour on the XS34. If I recall correctly you can, from the quick menu while executing a programmed recording, choose "Continuous power on". Then it will stay on after the recording finished.
    Maybe you enabled this by mistake?
  4. JB5
    JB5
    Apr 18, 2005
    231
    +16
    I assume that it is the same as with the XS30.
    If the unit is on when the timer recording starts then the unit will remain on after the timer has finished recording. If you want it to switch off after the timer recording has finished then from the quick menu select auto power off.
    Similarly, as described above, if you start watching something from the unit after a timer recording has started, and don't want the unit to switch off automatically once the timer recording has ended then select continuous power on form the quick menu.
  5. rap451
    rap451
    Hello everyone, thanks for your help and pointers, I guess I need to check my progs via quick menu or read the mammoth manual to try to understand what I need to do properly.
    Richard
  6. bernie_pt
    bernie_pt
    If I remember correctly, the quick menu option "Continuous power on/Auto power off" is valid also for intensive tasks, like dubbing/creating a DVD (like "shutdown when finish" on PC's programs).
