Toshiba RDXS34 output colour problem!
Discussion in 'Blu-ray & DVD Players & Recorders' started by jamba, Jul 15, 2005.
  1. jamba
    jamba
    Has anyone noticed a problem with the Tosh RDXS34 whereby if you leave it on for a long time lets say 4 hours or so while recording the colour on the TV becomes 'grayscale' kind of.
    It appears as though it has lost one of the colours and when you playback the recording the output is the same as what you are seeing i.i.e. with one of the colours e.g green missing. Is this caused by the machine overheating or is it just my particular machine which has this problem? or is it a faulty cable but it only happens when you are recording for a long time.
  2. JayCee
    JayCee
    Jan 20, 2004
    20,342
    Lanarkshire
    +1,954
    I suspect it is a problem with your particular machine.
    Unlikely to be a faulty cable as it would not be time-related.
    Obviously change the scart lead first and see.
  3. jamba
    jamba
    Thanks, I think that the problem is with my machine. i will have to ring Tosh and arrange a replacement unit.
