Toshiba RDXS32SB multi region DVD Hard Disk Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by jumbopants, Aug 22, 2004.
  1. jumbopants
    jumbopants
    Jul 31, 2003
    uk
    +4
    I'm going to buy the Toshiba from Unbeatable for 390 + 7 del. multi region unless anyone knows of any cheaper ? but before I do can anyone tell me what the SB is on the end of the model number ? Unbeatables site has it listed with SB on the end for some reason and I just wanted to check 100% that it's the same model that everyone else is selling and not a cut down uk version ? Can anyone shed any light on the SB ? as Unbeatable does not have the full spec of the machine listed, just being super cautious as I nearly got the the liteon 5000B which is the uk cut down version of the us model 5000A. It's alot of money for me to spend and I just want to get it spot on first time. Many thanks in advance for any help/replys....
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    Silver finish
  3. bobbles
    bobbles
    sub £400 price is a great price too
  4. jumbopants
    jumbopants
    Jul 31, 2003
    uk
    +4
    cheers for the replys....
