toshiba RDXS32SB DR-OFF
suziebaby2002
My Toshiba RDXS32SB is showing DR-OFF which seems to mean the remote isnt working. Any ideas how i can trun it back on. I havent got a clue what i did to make it go off.:lease::lease:
Thanks.
Sue
Gavtech
Administrator
Thanks.
Sue
I interpret that to most likely mean that the hard drive has auto-turned off after a period of inactivity.
It will auto-start again when you press play or record.
jjjpold
I've got the same exact problem with the same recorder and still didn't find any solution for months !! Each time i press a button on my remote i get this RD -off message but nothing works...
any idea ?:lease:
thanks
Gavtech
Administrator
any idea ?:lease:
thanks
I presume you mean DR off? Not RD off.
There is no indication that this is an option in the remote codes ... but it may mean that the remote code is not matching the machine.
There are 3 optional codes: DR1, DR2 and DR3.
The default code is DR1 and is likely what your machine is set to... Therefore try resetting the code on the remote to DR 1.
Use the following method:
Lift the flap on the remote.
Press and hold the Setup button located in the bottom left hand corner of the remote. Whilst holding, press button No. 1 on the keypad above it.
That changes the code to DR1.
Now try to see if the remote will operate the machine.
If not, repeat the procedure using the number 2 and 3 buttons in the sequence and see if those codes work with the machine.
Muttley1900
any idea ?:lease:
thanks
With my Toshiba RD-XS24SB, you can switch off and on the remote by "Press HDD and DVD on the Recorder at the same time for three seconds or more"
Hope this helps.
jjjpold
it finally worked by pressing the two channel buttons (up and down) on the recorder at the same time for more than 3 seconds...
Thank you very much for all your answers.
