Toshiba RDXS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by mr digital, Nov 28, 2004.
  1. mr digital
    mr digital
    Does anyone know the correct code for the remote control of this unit to be able to change the channels on my Pace DS430N Sky Digital set top box.
    I have tried both Toshiba & Pace & looked on the net but i cannot find any answer to this annoying problem.
    :lease:
  2. monocrider
    monocrider
    Have you tried 1520 ?
    Regards,
    John
  3. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    I'm also after the code for the Thomson FV boxes - either the DTI2300 or 4000 PVR box, which use the same remote controls.
    I tried 1480, which is the only Thomson code in the Toshiba manual, but it doesn't work :(
    Cheers,
    Ray D
  4. mr digital
    mr digital
    Thanks for the code John, it worked, i appreciate this thanks.
    Phil.
  5. moochin
    moochin
    Dec 10, 2002
    Has anyone a list of working codes for various makes of Sat receivers? Perhaps best to list it here and change name of thread. Would avoid similar questions asked in various threads.
  6. Ymegod
    Ymegod
    Nov 14, 2004
    175
    Bromley, Kent
    Hello,
    I have asked for a bit of advice on the RD-XS32 purchase advice thread, third down on page one.
    Any help appreciated.
