toshiba rdxs32 why thumbnails?
Discussion in 'Blu-ray & DVD Players & Recorders' started by stegalv, Mar 2, 2005.
  1. stegalv
    stegalv
    Dec 16, 2003
    886
    +36
    been using the panasonic e30 dvd recorder which was brilliant,but got fed up with the limited space of the disks.
    so decided to buy a hdd recorder,after reading about the tosh 32 which seemed to just edge out the panny, i bought one from rgb for £309,everything that people have said about it seems to be correct it is a good machine.
    (heres the but) but why have they used thumbnails to show whats been recorded i know i hav'nt had it long but it lets the machine down.
    with the e30 it grabbed the name of the show,so i knew exactly what i had on the disk now all i get is a thumbnail and i have no idea what the programmes are,i know you can change the thumbnail but who wants to sit after every recording sorting that out.
    or is there a way of changing the way it shows what has been recorded,
    when one manufacturer has a good idea why dont they all use similar versions,it's little things that make good machines a pain.
  2. El_JimBob
    El_JimBob
    Dec 4, 2004
    115
    16
    Actually, there is something quite relaxing about spending a Sunday afternoon in front of the Tosh fiddling with titles and thumbnails....
    Maybe your problem is you tape waaaay too much TV to keep track :D
    ....and mummy did tell you it'd make your eyes go square....
  3. SDHoward
    SDHoward
    Nov 1, 2004
    250
    The tosh has no way of grabbing to title automatically. I've got into the habit of entering the title when I set it up to record, which for soaps and things I only have to do once.
    If you don't like looking at thumbnails you can always use the library function, although without a title you will only have times and channels
  4. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    Sometimes I quickly set the thumbnail to the title of the show from the beginning credits.
    I agree it is a bind, and the teletext grabbing is a good thing, but most of the stuff I record onto the Tosh is straight from Sky+ in multi programme chunks, so autonaming doesn't work.
    What we need is a Freeview twin tuner version of the Tosh (off topic, but couldn't resist!) :)
