Toshiba RDXS32 tuner quality
Discussion in 'Blu-ray & DVD Players & Recorders' started by cuseeme, Aug 5, 2004.
  1. cuseeme
    cuseeme
    Just taken delivery of a Tosh RDXS32. Whilst it seems a great machine, the tuner seems very soft. I get a far better result rom the tuner in my old JVC VCR. Compared to that, the Tosh has poor colour fidelity (glaring reds), a soft overall look and is generally below par. Are they all like this?
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    No!
    Glaring reds? could that be a poor quality scart cable issue?
  3. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    The picture is a bit soft I agree. Thought it was me...
  4. cuseeme
    cuseeme
    I think I've sussed the oversaturation. <hangs head in shame> I have a 3 year old and he'd been busy with the remote. Re did all the setup again last night and it looks a lot better colour wise but still soft as noted.
    Semi related, I have a freeview box. I can obviously stick in videoplus codes and make the machine record from it's built in tuner. If I want to record from the freeview box (hopefully not as soft), do I have to do that manually or is there a way to make videoplus codes trigger use of the freeview box instead of the built in tuner?
