Toshiba RDXS32 Recording Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by jonnymatrix, Sep 20, 2005.
  1. jonnymatrix
    jonnymatrix
    I have recently moved house where i used to have NTL :( Recording used to work just fine with NTL and was very pleased with the Tosh box. I am now using Sky and for some reason am unable to record from most Sky channels like Discovery, E4 Etc.
    I get a message telling me that the content is protected. This is while trying to pause the Live TV or just plain recording. Have I done something wrong? as it is very annoying.
    If someone could shed any light on this it would be very much appreciated.
    Thanks in advance
  2. alan8477
    alan8477
    Dec 17, 2001
    574
    Pershore
    +5
    How odd. :confused: I have an XS34 and have never experienced this problem. Could it be something to do with your XS32 still being configured for your Tosh/NTL box in the system setup area? Did you used to use your XS32 to channel change your old NTL box?
  3. jonnymatrix
    jonnymatrix
    No never did channel changing before. I have changed the settings on the Tosh for the new STB, and tried the old settings again also.
  4. kocl
    kocl
    Jan 8, 2003
    589
    PORTUGAL
    +13
    I have that problem too, i had to buy a box to disable protection.
  5. foneman
    foneman
    Mar 25, 2005
    1,104
    48
    south london
    +23
    there should be no problem with E4 or discovery - the only protected channels are movies etc..
    what could be happening is your connections may be getting 'noise' that makes the DVR think its a 'protection' signal - make sure you use quality cables!!
  6. Dark Eyes
    Dark Eyes
    Jun 4, 2004
    124
    It sounds like the Sky box is putting the 'copy protect' signal into the video out - there was an issue with this a while ago I believe.
    I would contact Sky, or the box manufacturer and see if they can confirm this, or explain what else is happening.
    If you don't get it sorted out this way (will either be some menu setting or a firmware upgrade) then I suspect you will have to get a lead that removes the CP signal from the video feed.
  7. jonnymatrix
    jonnymatrix
    Anyone have any ideas where to get such a lead in the UK? or on the internet somewhere :)
    I am also speaking to Toshiba to see if they have any ideas.
    Any links etc would be much appreciated.
  8. jonnymatrix
    jonnymatrix
    Thanks for everyones help on this, pointed me in the right direction. Toshiba are sending me a new Firmware which fixes this problem.
    If anyone else is having the same problem then call 0115 9766958 excellent service for a manufacturer and no wait either!
    Thanks again
