Toshiba RDXS32 & DVD-RAM
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steve Tustin, Jul 25, 2004.
  1. Steve Tustin
    Steve Tustin
    Jul 10, 2004
    95
    Stil learning about this beast!
    Trying to put a Toshiba 4.6GB DVD-RAM in for the first time and it seems a VERY tight fit! I'm asuming that it has to sit *in* the tray before closing the drawer? Concerned that if I use too much pressure I may break something - anybody out there seen the same thing?
    BTW, there is virtually no noise from the unit unless my ear is very close!
    Thanks people
    :lease:
  2. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    The cartridge should just drop neatly into place - no pressure required.
  3. Steve Tustin
    Steve Tustin
    Jul 10, 2004
    95
    Remove outer plastic sleeve before inserting.......
    <Hides face in embarassment)
    :blush:
