Toshiba RDXS32 and DVD+R????
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ben Cole, Dec 9, 2004.
  1. Ben Cole
    Ben Cole
    Dec 1, 2004
    1,226
    Porthcawl and Southampton
    +113
    I am getting conflicting reports.....can it playback DVD+R or not?
    Can anybody with one confirm for me.
    Thanks,
    Ben.
  2. JFBUK
    JFBUK
    Oct 1, 2004
    16
    I can't be definitive but my Tosh won't play back Verbatim +R and +RW disks created with my PC SONY DVD writer. Both play quite happily in my standalone SONY DVD player
  3. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    643
    +7
    It's not in the list of compatible discs for playback, so no I don't think it can. I have a few and haven't managed it yet either.
  4. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Acording to here
    http://www.videohelp.com/dvdrecorders
    no
    however it might be possible to make them compatable with bit-setting, which I may give a go, if I can work out how to do it....
  5. jmontra2
    jmontra2
    I bought mine after reading in one post in this forum that it CAN read DVD+R
    I've tried several DVD+R recorded in DVD-Video mode with no succes.
    Nevertheless, it is a very good machine with a great picture quality in progresive by components.
    Good luck,
    Jordi
    Barcelona
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    The Toshiba RDXS32 can read some DVD+Rs. It is very fussy about them though - largely due to the fact that playback of 'plus' media has been disabled on that unit so playback is accidental. So far I haven't been able to get any DVD+RWs to work with it although I have only tried a dozen or so brands.
  7. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    I've tried a couple and no luck so far with either DVD+R or +RW. Not surprising since they're not on the spec list.
  8. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    I have used +R's with success in my Tosh.
    These have been created on my PC in two different ways, one a straight "disk copy" of a finalised DVD-R that I made on the Tosh, the others have all been "back ups" of commercial DVD's to stop kids breaking them.
    They were from blankdiscshop and were cheap Bulkpaq's.
  9. Ben Cole
    Ben Cole
    Dec 1, 2004
    1,226
    +113
    Thanks folks.
  10. drjoshua
    drjoshua
    You can play DVD+R´s if they are burnt with Booklet type. My NEC 1300 can´t burn with that option so all my DVD+R´s are useless unfortunatly.
    Others can!
    Check your settings for your dvd burner.
