Toshiba RDSX34 interference problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul_Lee, Sep 14, 2005.
  1. Paul_Lee
    Paul_Lee
    Hi all,
    I've noticed that, with my Toshiba RDSX34 on, or recording, I get a cross-hatched, undulating (ie moving right to left) interfence pattern on my TV. When I switch the recorder off, the interference is either non-existant, or so faint as to be nearly non existent (must be an artefact of where I live!)
    Has anyone else had this problem? And if so, how do I correct this? The only thing I can think of is that its cross-talk between channels - I am connecting my TV to my recorder using the RF cable and scart.
  2. Paul_Lee
    Paul_Lee
    Just noticed another problem: on ITV, when the recorder is running, I get occasional (every second or so) of "flashes" - red/grey bands appearing on the screen. They last for a tiny fraction of a second, just long enough to see them.
    Any suggestions....?
  3. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    Paul,
    I've seen some minor interference on mine just C4 I think, I havn't had the ITV problem. It seems to come & go but I haven't been able to fix it, but we mainly watch
    everything via sky so I wasn't too bothered (the effect was very minor & the wife didn't notice it!). Recordings appear to completely unaffected.
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Paul,
    I’ve not seen the “flashes”, but with my XS32 recorder I did have the problem with cross-hatched interference.
    In my case, I replaced the RF fly leads I had (one from freeview box to the recorder, other from recorder to the TV) with high quality shielded ones and that fixed the problem 95%. I got rid of the remaining 5% by simply re-routing my cables so that the RF leads were well clear of my electrical cables. So in my case it wasn’t the recorder itself causing the interference, it was simply that by adding the recorder I had additional RF cables near my power, and this was causing a problem.
    Mark
