Toshiba RDSX32
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stanman, Oct 17, 2004.
  1. Stanman
    Stanman
    Feb 7, 2004
    1,498
    +153
    I've more or less set my mind on this recorder but can some one confirm if I will be able to:-
    • High speed dub
    • I can split chapters on the HD
    • I can change thumbnail images
    • Menu creation?
    • Will it work with Qlink on my pannny TV?
  2. bobbles
    bobbles
    1) Yes
    2) Yes but you need to do it via a playlist
    3) Yes, you can also select any picture from the HDD as a background on your menus
    4) Yes, although limited to the default layout but you can select any background picture
    5) Absolutely no idea, but I doubt it
