Toshiba RDSX32 Burning fault
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jamiev70, Sep 18, 2005.
  1. Jamiev70
    Jamiev70
  2. skyline32
    skyline32
    Aug 9, 2004
    75
    I think that's what mine did too. I used to take the discs out and throw them away in disgust, but I recall there seemed to be a ring on the recorded surface which didn't look right.
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Did you consider that it might be a fault with the discs and not the recorder?
    By what mechanism would a laser, burning a linear concentric track, make a circular spot-shaped mark along the way?
