Toshiba RD32 Handset frooze
Discussion in 'Blu-ray & DVD Players & Recorders' started by TVHEAD, Jul 29, 2005.
  1. TVHEAD
    TVHEAD
    Nov 29, 2004
    59
    11
    My Toshiba RD32 Handset frooze, :cool: I have changed the Batteries etc, any ideas what could have caused this :confused: , or how to fix it ?, the machine works fine if I press the buttons on the recoder to operate,
    regards
    Colin,
  2. JayCee
    JayCee
    Jan 20, 2004
    20,351
    Lanarkshire
    +1,954
    I think you mean RD-XS32 :rolleyes:
    Was it dropped maybe?, anyway, unless your'e handy with a soldering iron there's not a lot you can do.
    If the pcb inside is broken or cracked you need a new remote.
  3. walrus
    walrus
    Dec 2, 2004
    Check that the remote is set up on the correct channel in setup - it's in the manual
  4. TVHEAD
    TVHEAD
    Nov 29, 2004
    59
    11
    Sorry it is the Rd-xs32 :D
    :thumbsup: :clap: :clap: :clap: :clap: :thumbsup:
    Got it working :thumbsup: when i pressed the remote i was getting the message BR-3 on page 55 of the owners manual , setting up the remote control give the answer ,
    While pressing setup i also pressed 1,2,and 3, this activeated the hand set when i pressed the 3, Thank you for suggesting the manual, i did look at the manual but only the page for error codes :rolleyes:
