Toshiba RD-XS34
Discussion in 'Blu-ray & DVD Players & Recorders' started by mutley_uk, Jul 24, 2005.
  1. mutley_uk
    mutley_uk
    I've checked previous post but couldn't find anything, so can someone help, I just bought a Tosh RD-XS34 and am trying to record a camcorder movie I made through the S video onto the HDD but every time I try I get a message saying that the movie is copy protected and then it recorder shuts down.
    Thx
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Is it a Sony Camcorder? Sounds like you may be seeing this issue:
    http://www.avforums.com/forums/showthread.php?t=207090
    If it is a DV camcorder, use a Firewire cable - you'll get better quality and won't see this problem. If it is an analogue camcorder and you need to use S-Video, then you need to contact Toshiba and try and get it repaired...
    Mark
  3. mutley_uk
    mutley_uk
    yes you are correct it is a Sony DV camcorder, I've now ordered a firewire cable to cure the problem.
    Thx
