Toshiba RD-XS34 IR number for Fergusion FDTT2500
Discussion in 'Blu-ray & DVD Players & Recorders' started by ianfor, Jul 29, 2005.
  1. ianfor
    ianfor
    Jul 29, 2005
    2
    Hi, just got myself the Toshiba RD-XS34 and none of the brand IR codes in the manual work for my Freeview box, a Ferguson FDTT2500. Any help would be appreciated.
    Ian
  2. al4n
    al4n
    Jul 16, 2005
    15
    might be obvious but i will still say it.has the ir cable been fully inserted in the channel change ir jack page 48 owners manual
    have you tried the freeview codes on page 50 as well as the ones on 51
  3. ianfor
    ianfor
    Jul 29, 2005
    2
    The IR control cable is connected as per the manual. I have had limited success setting the brand code to 1503 but not all numeric buttons work. 2, 3, 6 & 7 failing to operate.
  4. JethroUK
    JethroUK
    Dec 5, 2004
    1,144
    +34
    I have philips which has codes for 7 different ferguson boxes - none of which will work for you - but you might find this useful - lot of brands use the same codes - the ferguson codes also match:
    Thorn, Thompson, Telefunken, Saba boxes
    If you try some of the Tosh codes for these , i'm sure one will work it
  5. al4n
    al4n
    Jul 16, 2005
    15
    read a review saying your box as the insides of a thomson box,so as jethroUK says you could get lucky with a code
