Toshiba RD-XS34 controlling Sony VTX-D800?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cjedonline, Oct 24, 2005.
  1. cjedonline
    cjedonline
    I can't seem to get my Toshiba RD-XS34 DVD Recorder to control a Sony VTX-D800U Freeview box. I've e-mailed Toshiba Support, but no reply as yet. Anyone got this combination working OK? And if so, what code did you use ?
    Ta,
    cjed.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,508
    Bath, England
    +620
    I have a Toshiba RD-XS32, and I believe the codes are the same as for the XS34. The code I use for the Sony VTX800 is 1526.
    With this code, the "important part" works - i.e. you can programme recordings using Sat Control, and the Tosh will change channels on the Sony box. What I haven't got to work is changing channel on the Sony via the up/down arrows on the Tosh remote. But I'm not too bothered about that.
    Mark
  3. cjedonline
    cjedonline
    Thanks for that Mark - it does seem to change channel, but as you say, it doesn't work with the program up/down buttons on the remote. I'll test to see if it works with multiple recordings on different channels later.
    cjed.
