Toshiba RD-XS34 - advice needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by mobily, Nov 4, 2005.
  1. mobily
    mobily
    Dec 30, 2003
    505
    Plymouth
    +3
    Hey all,
    I have had a good old rummage through the various threads on this model but still have a few questions outstanding if that's ok :thumbsup:
    1) Is it possible to record something to the HDD whilst watching a dvd and record something to the HDD whilst watching something from the HDD?
    2) Will the machine allow RGB through whilst in standby using a Telewest box?
    3) Will I be able to use the Toshiba remote to operate the Telewest box?
    4) When I turn the Toshiba on will the Television automatically turn to it? At the moment when I turn on my dvd player connected to the component socket I have to manually select that channel, but when I turn the VCR and Freeview box on the TV automatically changes channel.
    5) Would the connections be as follows?
    Telewest RGB > Toshiba RGB input > Toshiba RGB output > TV
    Aerial wall > Toshiba > VCR > TV
    VCR Scart > TV Scart
    Toshiba Optical output > AV amp
    6) When recording something using Videoplus is the file given a suitable name on the HDD e.g. friendsep1? Or would I have to manually enter a name?
    7) What is Videoplus deluxe?
    What is the benefit of using the Toshiba remote to operate the Telewest box? At the moment I have a VCR, a DVD player and a Freeview box. If I want to record something from Freeview onto VCR I turn on Freeview and the VCR and then select the channel I want using the Freeview remote. Could I operate the Freeview box with the VCRs remote?
    Thanks :hiya:
  2. pilotsnipes
    pilotsnipes
    1) Yes. And Yes.
    2) Yes. Although you have to press the button labeled "SatMon" for this to work.
    3) Yes, although I can't tell you for sure if the toshiba has the telewest box infrared signals in it's memory. Also it will be limited to just changing channels. I'd REALLY recommend you getting a Harmony Remote ( 665 for example) to combine all your remotes....much better.
    4) If your TV is able to sense which input has just come alive (and you MUST have connected the Tosh to the TV with Scart) yes it will. From what you have written about your current setup it's almost certain that it will. Component cables don't carry the switching signal.
    5)
    Aerial wall > Toshiba (Toshiba RF output) > VCR
    Why do you need the VCR now? It's the headache in all of that.
    6) Never used Videoplus, but all titles that I've recorded only have timestamp by default, but you can manually add names yourself. Much easier if you set up a recurring recording, as you can then add the name once and it will always be added.
    7) Pass.
  3. ABP
    ABP
    Video plus deluxe is the ability to control (via ir extender) your telewest / sky box.
  4. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    How do you set up a recurring timer recording? I know I did this before but I couldn't last night. I used record menu, selected input, time etc. On date, I could select the date/day but couldn't figure out how to make it "every monday".
  5. narke
    narke
    Oct 30, 2003
    114
    Leeds
    +3
    When you highlight the date in the record menu press the down arrow on the centre control, it will scroll through the different options.
