Toshiba RD-XS32SB timeslip problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Katharine, Sep 15, 2005.
  1. Katharine
    Katharine
    Hi I have a Toshiba RD-XS32sb HDD recorder. I have it set up with a Philips TV and a freeview box and on the whole it works great. The only thing is it doesn't work when I press the Timeslip button to try to start recording a program I am watching. Rather than recording the channel I am watching, it starts recording whichever channel was most recently being recorded through a timed recording. Has anyone else had this problem or have any ideas how to fix it? Thanks
  2. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    You could be watching any channel, but your recorder (any recorder) will only the channel it's tuned to - answer is to watch via recorder tuner (not your tele tuner)
  3. Katharine
    Katharine
    Thanks for your help, I thought I was watching through the Toshiba as I was using the Toshiba remote control to change channels but discovered I was actually using the wrong buttons. Its the channel changing buttons at the top right of the remote that keep it working through the Toshiba not the ones on the bottom left. Problem sorted now and timeslip function working. Thanks again.
  4. marty2005
    marty2005
    Jul 22, 2005
    3,691
    Great Yarmouth
    +155
    My girlfriend thought my calculator was the tv remote
