Toshiba RD-XS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by CJT, Aug 23, 2005.
  1. CJT
    CJT
    I have recorded all my home movies onto the hard drive and saved them as chapters, 1 chapter for every month. The problem I have is that now my chapters are not in date order and I can't seem to find any way the rearrange them - can anybody help?
  2. sinclair
    sinclair
    Just off the top of my head I would set up a Home Movie playlist adding chapters by date. Then when you watch or burn the playlist they will be in the order you want.
  3. CJT
    CJT
    Thanks for the advice, I did as you suggested & then copied it on the hdd to make it original, the deleted the 'original' original
