Toshiba RD-XS32 & Sky
Discussion in 'Blu-ray & DVD Players & Recorders' started by bowler900, Sep 4, 2004.
  1. bowler900
    bowler900
    Jun 19, 2004
    90
    Downham Market, Norfolk
    +7
    Recently purchased a RD-XS32 and am very pleased generally with the recording quality and overall performance, the one thing I have a problem with is how to get the XS32 to change chans on the Sky box.
    The IR extension works as when I use SAT-CONT from remote i can change the chans on the SKY box however I cannot get SAT to appear in the timer record menu although chan 99 is set to SAT.
    Anyone have any ideas or am I just being thick and missing something
    I am using component out with a Sony Plasma
    AV2 Input from early Panny Sky box
  2. bobbles
    bobbles
    when you set a timer record, press sat cont then enter the sky channel number you want it to record.
