Toshiba RD XS32... How to Reset??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Del, Nov 3, 2004.
  1. Del
    Del
    Nov 15, 2000
    782
    Berkshire
    +16
    Anyone?
    How can I reset the above toshiba recorder to its out of box setting (factory settings)??
    Reason... I've been playing aroung with the AV output settings and have just lost all picture :suicide:
    I cannot now see any images from DVD, HDD or TV on my screen although sound output from any of theses sources are fine!! This also means I can't see the menu.
    Del :lease:
  2. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Not sure how to reset it, but have you tried connecting it to the tv using av2 instead of av1 as some of the settings only effect av1...
    have fun
    Steve
  3. alicat
    alicat
    Oct 13, 2004
    92
    Have you pressed the TV/DVR button on the remote control???
  4. Del
    Del
    Nov 15, 2000
    782
    Berkshire
    +16
    Hi guys
    Thank you for the hint guys.
    Alicat....I had tried the tv/dvr button to no avail. Ta anyway.
    Steve, changing the connection to av2 worked.
    Once again thanks :D
    Del :smoke:
